Haven't look yet this year since all the VAT increase stuff...Evenin' all,Was wondering where the cheapest place to buy 10mm T&E is at the mo??
B.
Aye Badge, but it's black and red. You'll need one of those stickers on the CU.........ebay:run :^O
how do you think i managed to wire our 9.5 kw shower with the old red/black 6.0mm that we used on our old shower circuit, found a piece to go from pull switch to shower in red/black aswell in back of shed :^O :^O :^O :runAye Badge, but it's black and red. You'll need one of those stickers on the CU.........On the plus side, you won't need to notify it.........
does that mean the chappy picking it up from you needs a vehicle that can take the weight of a ton :^OIf you are anywhere near Lyme Regis I have a 50m drum that I got in error (must get to optician soon, I actually needed 6mm) that Ill let ya have for a ton. Posting it would probs cost the earth tho so not really worth it
It does seem to weigh about that yesdoes that mean the chappy picking it up from you needs a vehicle that can take the weight of a ton :^O
Nah, PC, buy by the 100m, charge by the meterI can't really afford to keep 50m or 100m reels of 10mm on the van (not to mention the bulk and weight), so when I need it I buy it by the metre from Edmundsons. Just get the price on the day and charge it to the customer.
Do so with all the sizes up to and including 6mm, but don't use enough 10mm to warrant it.Nah, PC, buy by the 100m, charge by the meter!
Thanks mate, but have no use for that much and don't know where Lyme Regis is... ?:|If you are anywhere near Lyme Regis I have a 50m drum that I got in error (must get to optician soon, I actually needed 6mm) that Ill let ya have for a ton. Posting it would probs cost the earth tho so not really worth it
it didnt cost us virtually anything to install our shower, because all i had to pay for was the cable and the 45amp switch, the 40amp rcbo was from the exisitng shower just i updated the wiring and the shower to 10mm 9500w from 8000watts has been itting on a 40 amp rcbo now for 2 months and only pulls a max of 30amps ish, no where near the full load mind you its not turned that hotThanks mate, but have no use for that much and don't know where Lyme Regis is... ?:| Thanks for all the replies guys, apparently a couple of local suppliers sell it buy the meter.
What shocks me the most is that people buy electric showers cheap and then spend loads getting them installed.....
B.
Paul Karnel!!!!!!!!!!!!!!!!!!!!!!
