dont see anything wrong with that suggestion. maybe see if a split phase board exists with only L1 and L2 busbarsfound this on another forum"You could try an 18w db fitted with dp mcb's fitted to L1 & L2 and a blank fitted to L3 and then work your way down the board then terminate the 110v mains onto L1 & L2 of the db disconnector
yours benji "
is that an accepted method??
It does.... In America. Their supply is 120 either side of neutral with dual breakers for big appliances like cookers or washers. (240v)dont see anything wrong with that suggestion. maybe see if a split phase board exists with only L1 and L2 busbars
not seen them here either, but its not something ive looked for. they can probably be made to order though form somewhereIt does.... In America. Their supply is 120 either side of neutral with dual breakers for big appliances like cookers or washers. (240v)Not seen any two phase DBs here in the UK.
