sheryl
I've tried uploading photos but it says they're too big ?
Not really job for none spark but could guide you through it but only in real talk not textHi guys and thanks
ProDave - definitely 2 cables but looks like 1.5mm.
Live and unsheathed earth from one cable. The live goes to the L1 and the earth is with another earth in one sheath to the earth terminal. The other cable has live, earth and neutral. The neutral goes to the COM terminal and the earth is just hanging there - not connected to anything.
I would like 2 switches - next to each other is fine - one a normal switch for the kitchen area and a dimmer (which is there already) for the dining side. Running a cable is no problem - the bedroom and bathroom floor are up already![]()
Sharpend - thanks you too. It would be so much easier if I could just put a pic up but there is just one cable - twin and earth from the ceiling and connected to the light fitting which on the kitchen side is a bar with 4 spotlights on.
Thanks a lot guys x
