blastcleaner
- Jul 16, 2008
- 14
- 0
To run 2 single phases into a domestic property, do I need 2 seperate switch fuses off the main bus bar, or can I use 2 phases out of an unused 3 phase 63amp switch fuse that is already there?
I am a learner, so cut me a little slack guys if this is a silly question.
Using two legs of a 3 phase switch fuse does not sound quite right but on the other hand seems like a good idea, it would ensure isolation of all supply during maintenance, no chance of confusion (but of course one would always use a proving unit) Doing a bit of planning to upgrade the power supply to my bungalow that sort of keeps growing.
The proposed underfloor electric heating is going to throw the loading calculation all to hell if lots of things come on together and the existing 60's overhead private wiring will glow !!!
The farm has a 200 amp 3 phase PME supply. I want to run 2 phases into the dwelling underground from the distribution board. Its all a bit cluttered on the incomer board, so I am trying to plan and use what is there if possible.
Thanks.
Thanks.
