2 Products With Hdmi Cable Only 1 Port
shiner
Active member
May 30, 2013
31
romford
I have a customer with a samsung TV it appears to have a HDMI in and a HDMI out.
her sky box is plugged into the in port but she also wants to plug in her Apple TV also.
Is there such a thing as a double adaptor or splitter.  Or can it be done.
doubt it would have a hdmi out tbh! probably 2 hdmi's can see the point of an out as what ever is coming in would just go to other screen. but as said yes can get splitters seen them upto 5 way
Worth checking the user guide. Some TVs have an HDMI marked ARC out. This is still an hdmi input but also feeds the 'screen' audio back down that hdmi cable so at the other end a surround sound system can process it for a multi speaker system. Often HDMI 2 has ARC out as people like their sky box on hdmi1 and the surround system can then hold of the sky multichannel audio if sky is on screen
Otherwise yes get a splitter or use an AV amp with many inputs and a single hdmi for the monitor
Should state the obvious.
ARC = Audio return channel
This is a picture of the manual. I hope this helps.
She also doesn't know how to remove the tv from the wall mounted bracket any help or advice is greatly appreciated.image.jpg
