2 Wire Inductive proximity switches
FozzyTime
Jun 14, 2012
11
Hi guys,
Im putting In a 2 wire proximity switches but been told that it does not need a supply to it (hence 2 wire), it can just be wired to the coil of the relay, im my case A1. I dont understand how these work. anyone shed any light on it for me?
Cheers
Mike
If its an inductive switch, then it`ll "induce" (clue in the name) a voltage in the head, which could operate a coil - though it`ll only be momentary ( unless the other "half" of the switch IS powered?)
thanks for the reply, then why would u ever use a 3 wire switch as you would need a psu to power it? Would it not make sence to just always use a 2 wire as no suplly is needed?
I am making a suggestion by writing this.
It could be that the operating method of
the proximity switch is that the electrical
properties of the circuit are altered by the
closure of the switch. This may explain
why it is only two wire.
The first thing I thought about was a change
in the dynamic impedance of the circuit
caused by the switch closure. The dynamic
impedance of electrical AC circuits alters
as resonance is approached. This may be
an explanation but I stand to be corrected.
I am making a suggestion by writing this.It could be that the operating method of
Hi tech how comes your text doesn't fill the post up widthways it stops half way. Whys that ? :)
I doubt that the switch would power a relay coil.
As has been suggested, it would be useful to have the switch details.
BTW, most are inductive, they are more reliable, as long as what you are sensing will work with the switch.
Matty; When I first began to type I had an old
sit-up-and-beg machine. I still have it. It is an
ornate model, with a beautiful key action and I
keep it well oiled.
You might think me crazy for paying
and he has a returnkey, just like this
one on my keyboard.
I hope this doesnt
catch on, takes me
hard enough typing
normally most days.
It's a return lever, Steps. It makes a
lovely sound as the carriage slides
down the guides after the ratchet has
rotated the scroll.
