Revved Up Sparky
Hello everybody. I am coming to the end of a big job, rewiring a 500 year old Anglican church. I have installed four 2KW wall mounted quartz optical heaters using two radial circuits wired in 2.5mm twin and earth and protected by 20A type B MCB's. The runs are quite long, maybe 30M each. The two heaters on each circuit (which have their own 13A FCU next to them) are switched on via a 20A DP switch near the consumer unit.
With each local FCU switched off you can flick on the 20A DP switch then switch on the heaters one at a time without any problems, however, when you flick the DP switch with both heaters in circuit the MCB trips. The same thing happens on both circuits. I have tested the IR and both circuits are clear.
Does anybody know if these heaters have high start up currents ?. The actual design current is 17.4 amps. I am wondering if fitting type C MCB's will fix this problem.
Any input gratefully received, thanks all.
