Adding another circuit to and old cu
Lexicon
Aug 23, 2021
3
I need another radial circuit adding to our cu board to supply a new shed / workshop. We had an an eicr done before moving into this house a year ago and the cu was deemed unsatisfactory because in does not comply with current standards, being installed in 1979. It does have rcd protection rated at 100ma.
Can a new circuit be connected under current legislation? or is a replacement CU mandatory?
So you spent many many £000's on buying a house including due dilligence and getting an eicr done, but have decided not so spend a few £00 getting the electrics upgraded, which you knew before you bought needed to be done?
Perhaps now is that time?
I can't quite figure out from your post if remedial work has been carried out to make the installation satisfactory for continued use following the EICR? (if not, why not?)
If it is still not satisfactory then I would not recommend adding any new circuits or extending any existing circuits..
Always keep in mind that electricity is invisible, difficult to hear or smell but it can kill a healthy adult in less than a second..
and I believe it is still used in some parts of America to administer the death penalty!!
And..
Electrical alterations/additions are NOT about making something work.. (which is the typical DIY consideration)..
Professionally designed electrical alterations/additions are about ENSURING that in the event of a fault the source(s) of energy will be disconnected fast enough before any people, property or livestock could be put into any danger!!
