203 help
Mikeymike
Feb 7, 2010
36
Hey all,
Got my 203 soon and I did a past paper recently and will someone be kind enouth to correct me if am right or wrong please my answers at the bottom. cheers
1: In situ measurements can be taken
a: OFF the installation drawings - my answer
b: OFF the finished drawings
c: From the tender drawings
d: Measuring quantites onsite
2: Which of the following does an RCD not protect against?
a: Earth to line faults
b: Earth to neutral faults
c: Line to neutral faults - my answer
d: Line to earth faults
3: From the on-site guide the maximum external earth loop impedance for a TT system is
a: 0.8ohms
b: 21ohms
c: 0.65ohms - my answer
d: 0.35ohms
4: a low earth fault loop impedance path is necessary for
a: Maintaining the neutral at earth potential
b: Small circuit condutors to be used at the design stage
c: MCB's to operate within specified disconnection times
d: RCD's to operate within specified disconnection times - my answer
5: The most effective medthod of controlling is to
a: The use of PPE
b: Use guards or barriers
c: Using enclosures
d: Eliminate the hazard - my answer
6: A fluorescent luminaire is also known as
a: High pressure luminaire metal halide
b: High pressure vapour
c: Low pressure mercury vapour - my answer
d: low pressure sodium
7: Why is it necessary to maintain a record of materials delivered to site?
a: To monitor and record staff efficiency
b: Check materials used and maintain stock - my answer
c: Purposes of billing the client for work done
d: confirm the cost of the installation on completion
8: One reason to balance 3 phase, 4 wire installation is to?
a: Have a connection for the neutral - my answer
b: Ensure you do not receive a shock from the earth potential
c: Allow single phase loads to be connected
d: Keep the running costs to a minimum
9: Losses from the theft of tools and materials can be most effectively reduced by
a: Placing barbed wire around the perimeter of the construction site
b: Using a suitable lockable container for storage - my answer
c: Using a CCTV on unguarded equipment
d: putting a lock on the main gate
10: The primary fuction of the National Grid is
a: The transmission of power between generating stations
b: allowing generating stations to determine the allotted power demands
c: Re distribution of power from the sub-station to consumer - my answer
d: The transmission of power between generating stations and distribution points
11: Any left over waste materials must
a: Be stored in suitable containers off site
b: Be the responsibility of the main contractor to remove
c: Be disposed of into the nearest skip
d: Be stored in the site container - my answer
12: How many number of turns are needed on a transformer if the primary windings are 1000 and the primary current is 5A and secondary current is 20A
a: 2500 turns
b: 250 turns - my answer
c: 200 turns
d: 150 turns
13: The five main stages of the risk assessment procedure are
1 Identify
2 Evaluate
3 Record
4 Implement
5 Review
The order in which they should be carried out is
a: 1,2,3,4,5 - my answer
b: 2,1,4,3,5
c: 1,3,2,4,5
d: 2,3,1,4,5
14: The risk of electric shock can be most effectively reduced by
a: Using a SELV supply - my answer
b: Using a 400v dc supply
c: Using a 230v ac supply
d: Using a 100v ac supply
15: The minimisint of risks in the workplace can best be achieved by
a: Periodically reviewing risk assessments - my answer
b: Ensuring all staff purchase their own PPE
c: Testing of electrical equipment every 3 months
d: Recording all movements of site personnel within the construction site
These would be my answers :
1 -D
2 -C
3 - B
4 - D
5 - controlling what ?
6 - C
7 - B
8 - D
9 - B
10 -D
11 - D
12 - B
13 - A
14 - A
15 - A
Hey all,Got my 203 soon and I did a past paper recently and will someone be kind enouth to correct me if am right or wrong please my answers at the bottom. cheers
d: Measuring quantites onsiteThe question asks for in-situ measurements
c: Line to neutral faults - my answerQuite correct
a: 0.8ohms
b: 21ohmsI think they are after this,,, it's the maximum earth loop for a substation!?!?
d: 0.35ohms
c: MCB's to operate within specified disconnection timesyou need a low earth loop for the magnetic part of the MCB to operate
5: The most effective medthod of controlling is to controlling what??
a: The use of PPE
c: Using enclosures
c: Low pressure mercury vapour - my answerYep
b: Check materials used and maintain stock - my answerthis is what I'd go for
d: Keep the running costs to a minimumMy guess
b: Using a suitable lockable container for storage - my answerYep
d: The transmission of power between generating stations and distribution pointsThis one
b: Be the responsibility of the main contractor to removeIt's the responsibility of the company producing the waste to get rid of it
a: 2500 turns
b: 250 turns - my answer4:1 ratio
c: 200 turns
d: 150 turns
1 Identify
2 Evaluate
3 Record
4 Implement
5 Review
a: 1,2,3,4,5 - my answerYes
b: 2,1,4,3,5
c: 1,3,2,4,5
d: 2,3,1,4,5
a: Using a SELV supply - my answerYes
a: Periodically reviewing risk assessments - my answerYes
Not having done this exam or course,, mine in RED
Cheers for the answer I've got few more if you wan't have a go
1: The power factor of a resistive & capacitive circuit having an impedance 3ohms and a resistance of 2.5ohms is?
a: 0.83 leading - my answer capacitive leads & inductive lags.
b: 0.63 leading
c: 0.83 lagging
d: 0.63 lagging
2: To many appliances connected to a ring final circuit can cause what kind of fault?
a: Overload - my answer
b: Earth fault
c: Short circuit
d: Visual fault
3: High currents in a supply cables can be most effectively measured by
a: Using an ammeter in series with the supply cable
b: Using a current transformer
c: Connecting an ammeter across the supply terminals - my answer
d: Digital wattmeters
4: A circuit consisting og an induction of 0.12Henrys is connected to a 50hz supply. The inductive reactance is?
a: 37.7Kohms
b: 86.67ohms
c: 37.7ohms - my answer - 2xPI x 50 x 0.12
d: 86.67Kohms
5: Force on a current carrying conductor can be demonstrated by using
a: Fleming's left hand rule - my answer
b: Fleming's left hand grip rule
c: Fleming's right hand grip rule
d: Fleming's right hand rule
6: the correct appearance, knowledge and attitude is necessary to
a: Assist in procuring more finances when the submitting a tender
b: Improve the chances of charging more money for a job
c: Project a professional appearance and improve future contract opportunities - my answer
d: Look good when members of the opposite sex walks past site
7: Which of the following is not classed as an exposed conductive part?
a: A metalclad socket outlet
b: An incoming water supply pipe - my answer
c: The metal casing of a motor
d: A brass dimmer switch
8: If you discovered what you consider to be a serious risk to health whilst at work, what is the best course of action?
a: Attempt to remove the risk
b: Record the risk on a risk assessment
c: Contact your supervisor - my answer
d: Ignore the risk
9: If an electrical circuit supplies equipment outside the equipotential zone
a...
a: BS 1362 fuse must protect the circuit
b: Longer lead must be used
c: MCB must protect the circuit
d: RCD must protect the circuit - my answer
10 - Isolation of an electrical ciruit should be proved
a: Using an approved voltage indicating device - my answer
b: Using an earth fault loop impedance tester
c: Using a multimeter
d: Using a neon screwdriver or glow stick
11: Power factor correction of a large industrial installation can result in
a: Lower energy bills
b: A reduction in the supply voltage
c: An increase in the unit power
d: Higher energy bills - my answer
12: Before work begins, you should carry out a survey highlinging potential hazards within the work area. This is known as a...
a: Risk assessment - my answer
b: Site safert policy
c: Survey of identified risks
d: DSEAR report
Sorry can't be bothered with calculations.. it's 20+ years since I've had to work out reactance and phase angles
all seem right except for no.3
High supply currents are measured by current transformers!
I just passed my 203.I revised using Swindon massive and smatscreen.While going through the whole unit in The trevor linsley basic level 2 book.
I hope this helps someone
