Ok....
So, what is the idea of bonding.... to create an equipotential zone..... Now, an extraneous part, is a Part liable to introduce a potential, generally earth potential.......
So there we are and we have an earth fault, and an exposed conductive part of whatever we are touching becomes live due to insulation failure, whatever.
We do not care, we do in fact, not even notice, because we are standing on an insulating floor covering. We touch the sink, we still do not care, as it is bonded to the MET [same as our conductive part], so even if the earth conductor is removed, we still do not care. No potential difference exists between anything we can touch....
Now sticking through the wall is an extraneous part, this IS at earth potential. We touch this and we have a terrible shock!!!! So how do we avoid this?? we bond extraneous parts to the MET. But how do we know they are extraneous???
We measure the resistance between the part in question and our MET. Everything else is connected to the MET so what we need to know is, if, in the event of a fault, can enough current flow between the MET and its associated "bits" [all the conductive parts etc] and the "extraneous" bit we are testing, to harm us.... [Remember this; in the event of a fault, if we are touching both a conductive part, and an "unbonded" extraneous part, WE form the earthing conductor!!!!]
Now, if we have an earth fault, for the duration of it, everything in the equipotential zone is going to be near, or at, line voltage. From this, we can see that it is line voltage that we need to apply to our "extraneous" part, in order to be able to measure how much current will flow, and, will this current be at a "safe" level. In practice, this would be impractical [eh!] so the nearest and best thing we can do, is to measure the resistance from the part to the MET using a tester that applies around about line voltage, so that would be about 230V, so 250V is used.
If we find the resistance is high enough, we can then be certain that not enough current will flow to harm us, and that we, from the point of "extraneousness!!" can forget about this object. What resistance do we need though??? Well, if depends on circumstances. In a DRY location, about 20K ohms is fine. In wet locations though, a person might be all wet, and wet [salty] skin conducts rather better than dry, so to compensate for this we would be looking at finding a resistance of more like 50K ohms
john....
