2391....
jl-heating
Distinguished Member
Dec 16, 2008
1,158
4 weeks and counting ..tick tock tick tock...............!!!!!!!!!!!!!!
andyc prepare urself there are lots of questions coming your way ..
4 weeks and counting ..tick tock tick tock...............!!!!!!!!!!!!!!andyc prepare urself there are lots of questions coming your way ..
got mine tomorrow .... PrayPray
gulp.
These electrical courses provide first class information in a presentation style format for the first course, and a word course notes style for the second course.
The courses should be tackled slowly and the information taken in week by week, the 2391 exam is one of the hardest electrical exam you can take in the U.K. it has a pass rate of only about 10-20%.
If you follow this course carefully you can easily pass your 2391 or any other electrical exam as these courses contain info relevant to any electrical course in the U.K.
The course should be followed as listed below:
Week 1 & 2 - Inspection & testing basic
Week 3 - Instruments & testing
Week 4-6 - Inspection & testing advanced
Week 7 - Earthing arrangements
Week 8 - Earthing Calculations
Week 9 - Certification & inspection
Week 10 - REVISION QUESTIONS 1 & 2
Once you have completed this you can go into the word course, you should be able to follow this easily after the 10 weeks. Spend another 5-6 weeks studying the word course.
Once you have completed this course you will need to sign up for an exam at a local college. You should pass easily if you follow this course.
i need every bit of help i can get :)
apparently 33 % chance of passing it .. i hope the retest is not to expensive.
I have already done the fundamentals of inspection and testing 2392 I think? :|
The 2391 practical is not too bad
Full inspection and test of a three phase distribution board with a sub ccu supplying other curcuits.
An inspection board to identify 12 faults
an isulation resistance test and
a Zs measurement ... confirming conformity.
Guiness DrinkGuiness DrinkGuiness DrinkGuiness DrinkGuiness Drink
The written paper is a whole different kettle of fish ......
though after doing countless past papers Im as prepared as I can be . :|
Guiness Drink
providing the board is a little easier than this, i should manage it
doesnt help when circuit chart is very wrong, and 2 way radio's didnt work...
Andy I want to come and work with you if thats what you come across on a daily basis ! ;)
Guiness Drink
Andy I want to come and work with you if thats what you come across on a daily basis ! ;) Guiness Drink
not daily. dont work on stuff that sized often. as soon as PIR was finished for there, next job was to strip out half the circuits!
busy with another 3 phase board (new install) at the moment. ill get some pics of that up tomorrow
thats the interesting, get you thinking type of work I want to be doing ! :)
Guiness Drink
Good luck Sarni.
I did 2392 a couple of weeks ago and passed so gave myself a rest from the books while the sun was shining.Getting started again ready for 2391.
Apart from GN3, got any other recommendations for books/sites for info.
Cheers.
Good luck Sarni.I did 2392 a couple of weeks ago and passed so gave myself a rest from the books while the sun was shining.Getting started again ready for 2391.
Cheers.
If your confident with the tester.. then the practical will be a breeze ;)
for the wriiten .....
yes GN3 inside out / back to front !
gs38 cos you know there will be a question on
Finger guards
Fused probes
Four mm exposed tip (pref 2mm)
Flick through the
Memorandom of Guidance of the EAWR:z:z
other than that work through lots of past papers and try to resolve problems found on the Forum.. I ve found it very usefull. ;)
providing the board is a little easier than this, i should manage itdoesn't help when circuit chart is very wrong, and 2 way radio's didn't work...
Nice one M8Applaud SmileyApplaud Smiley:x
but you are a little ****** you..!!!
mooching around Admins motorised shed!!
thats his Garage & Shed supply isn't it?
hope he's paying you good to sort it!! :^O :^O
:coat
If your confident with the tester.. then the practical will be a breeze ;) for the wriiten .....
Finger guards
Fused probes
Flick through the
Cheers for that. Do quite a bit of testing so the practical side of things doesn't worry me too much. It's engaging the brain that gets me every time.
