2391....
why me?! i don't even have 2391!!!!
You can borrow mine..... :p
I managed to capture a 2391 back in May 2000......
roaming free...
it got separated from the heard..
so I bagged it with my C&G gun!!! :^O :^O
don't use it every day... :eek:
so you can borrow it:x
But ONLY if you can get me the FELT PENS of Patch;\Blushing
Thats the PERMANENT ones.. not washable!!!! ]:) ] :) ]:) ] :)
:D
Guiness DrinkGuiness DrinkGuiness DrinkGuiness Drink
whens the medication Admin? :p :p:p:Y
Do as many past papers as you can to get the hang of questions and then apart from the Earth fault path which you have to draw from transformer to fault and the back along the Earth return path and label all the parts, and having to calculate cable lengths from given amounts revise as I don't think hardly any questions from past papers came up in my exam oh and good luck CJS
How did the 2391 Go, Sarni? (In your opinion - I know it will be some time before you get the results).
Or was you just starting the course Today?
I am suprised nobody has mentioned the OSG or the two books from "Amicus Union". They are well worth a mention.
Got a link for the 2 books admin?
bloody hell just done the 2391 exam and aint all that happy.
i'll be very surprised if i manage to scrape a pass out of that!
any one else do it this evening??
just got my practical to look forward to tommorow morning :D
hi done mine in march and passed i would recommend
EXAM SUCCESS
inspection and testing 2391-10
isbn:978-86341-899-0
hi done mine in march and passed i would recommendEXAM SUCCESS
yeah bought that book. it is good. was fine with the example tests they gave me but the exam i had threw in a lot of things I wasn't banking on.
Congrats for back in March then!
Applaud SmileyApplaud SmileyGuiness DrinkGuiness DrinkGuiness Drink
my mate took his tonight i spent some time over the last
week with him going over questions.
was the earth fault loop impedance path
with diagram and labelled in there.
i bet him it would be
cheers special l yes the wait was harder than the exam
got my results 20th may
How did the 2391 Go, Sarni? (In your opinion - I know it will be some time before you get the results).Or was you just starting the course Today?
HI
good thanks... I think???
Usual section A style questions,
certificates, gs38, rcds, type of tester to use for certain tests and range.IP ratings, safety notices......
Section B was ok too, easier scenario than Id expected and most of the questions aimed towards the testing process ie
How would you perform an insulation resistance test on the installation?
Quite a few rcd questions, additional protection for and all that.
calculating Zs and confirming conformity...
my mate took his tonight i spent some time over the lastweek with him going over questions.
Oh yeah and that question too ...
Guiness Drink
HIgood thanks... I think???
I see. :D What are the ranges guys. So many ranges given. I will have one in my 302 or 303, no doubt.
low resistance ohms meter 20ohms range
earth loop fault impedence tester 200ohms range
insulation resistance tester Mohms range
rcd tester ms
Guiness Drink
Thanks Sarni - I know them. I was asking more along the lines of Continuity 0.05 - 200ohms etc.
Thanks Sarni - I know them. I was asking more along the lines of Continuity 0.05 - 200ohms etc. :|
oh right sorry .... Ill try again :coat
in the examiners report it does mention about candidates mixing up.... acceptable test results for a main bonding results (in the order of 0.05ohms)
with another question asking for the Range of a low resistance ohms meter. (20ohms range)
and the same for an elfi tester Range (200ohms)
This goes back to the old Avo analogue meters and the like when you had to manually select the test Range (Sensitivity) of the meter.
Guiness Drink
