Hi guys,
Got a job to wire some new emergency lights in a residential home we look after.
Currently the entire buildings emergency lights are supplied by a 24v DC central battery system. The system also has a timer installed to switch the lights on at night to provide night lighting for the elderly residents as the main communal lighting is PIR opperated so takes a second or two for the fluorescents to kick in.
There were additional lights installed on the battery system a few years back and no one took volt drop into consideration. Its been drawn to our attention that these fittings are blowing lamps within days of being fitted. After measuring the voltage at these fittings there is only 18v ish.
To rectify this we are replacing the lights with 230v AC 8w maintained bulk heads. There is a 230v permanent live and neutral available at the 230v fluorescent fittings next to the 24v dc fittings which we can use for the new 230v emergency fittings charge circuit.
What i dont have is a 230v switched supply to switch the fitting on at night as a night light. So ive come up with the idea of using a 24v dc relay to create a switched supply. So when the battery unit switches its 24v supply on for the night lights, the relay will drag in and switch the 230v maintained side of the emergency fitting.
Now im fairly recently qualified and not afraid to admit when im not 100% sure on what im doing in terms of wiring the relay.
Would anyone be so kind as to explain to me what pins i need to connect my
A) 24v DC Switched supply (From Central battery unit)
B) 230v Permanent Supply
C) 230v Switched Supply (Switched via relay)
I have an 8pin relay and base.
Thanks alot,
Russ
Thanks alot,
Russ
