3.5mm Tap
m4tty
Scaredy cat™
Feb 5, 2009
5,612
Hi,
Is it worth getting a 3.5mm tap for when the lugs on backboxes become cross threaded.
If so wheres best to get one from cos its not worth buying a set of taps and dies just for the 3.5mm one used for re-threading lugs
I think they are called thread runners and wholesalers are best bet, I get the longer version as they reach the parts others dont!
real valuable tool, mines a draper one about the size of a small screwdriver.
http://www.tlc-direct.co.uk/Main_Index/Tools_Index/Taps_and_Threaders/index.html
Or similar.. make sure you get one with a long shaft..
e.g.
some only have a short shaft approx 25mm
whereas others are 50mm!
you will need the length on some back-boxes..
such as when they are sunk behind tiles!
I was told you can't beat a longer shaft!
who was it who said that?........ ]:)
oh yes... Mrs Special:Blushing
But I never knew she had even installed any electrical back-boxes! :p :|
just goes to show you learn something every day! :eek: :p
:coat
Bought mind from fleabay. Long one, as mentioned above.
I bought it, when someone posted a link to it on here..
.. Where's our Patch. Odds on that he will find the thread with the link in question.
:D
That maybe the one StephenH, Or one like it, at least.
Even I have one!
(blue handle)
I use mine all the time. I even run it through the threads on new boxes - it's surprising how even small amounts of debris can damage the screw threads.
Concur! :Applaud :Applaud:)
That has become my standard practice over recent years..
The quality of threads on most back boxed is just a lump of doggy doo IMHO!
And if the screws are a bit softer you end up wrecking the screw threads before you even got the bloomin socket on! :_|
