3 Gang 1 Way Replacement
goahead
Nov 23, 2013
West Sussex
I am replacing a 3 Gang 1 Way dimmer, and was sent by mistake a 3 Gang 2 Way. Can i use it to replace the faulty 3 Gang 1 Way ?
If so, how ?
Thanks in advance
yes, using a 2way in place of a 1way is simple,
the terminals should be marked
com
L1
L2
or similar, for 1way simply use com & L1
or, as Barx says, tell us the markings and we can for definate tell you which term NOT to use.
I am just glad this is in the DIY forum!
Many times  most retailers will stock one item and for the difference in price it makes commercial sense. A two way and a one way are almost the same thing in wiring terms.
On the switch you will see a common denominated terminal, this is normally a permanent live connection from the lighting wiring circuit, and another terminal identified by L1. For wiring purposes these are the only two terminals you should be looking at. It also makes no difference which cable you connect to common or L1.
The switch will operate all the same. There is no need to wire anything into the terminal designated L2 unless you have a two way switch, commonly seen on stairs or corridors
My opening  comment is not a derogatory remark against yourself, its just that now and again we get some paid electricians asking the very same question. .
Very true too the above. So if you want to have your switch off at the top, you must get it right if you get it wrong and you have the switch in the on position but the light is off, you will have to swop the wires around.
The reason I asked for connections is 'some' switches are labelled different. common layouts:
com, l1, l2
l1, l2, l3
com, 1way, 2way
com, 1w, 2w
either way, you leave the latter most connection
Are I just read dimmer, are well it's Friday and wine makes a difference, where's my glasses
Very worrying confused about dimmer switch and day of week.
More water is needed.
