Hi All
I have been asked to install a large 3 Phase generator to run a 200hp motor. The generator unit will be outside a large barn,suppyling the plant inside. He wants also to use the existing supply to the barn, to run other equipment.
I have told him that this would not be acceptable and would have to run everything of the same supply ie: all plant machinary.
Looks like I will have fit a 3ph Dis board to run all this gear which will be only feed by the generator.
Any thoughts on this would be apprieciated.
