- Feb 27, 2008
- 11,018
- 0
Evening all
With the introduction of the 17th edition of the wiring regs and having to comply ie cables in walls. Cooker circuits needing to be put through 30mA RCD.
I was always told not to put Cooker and Immersion circuits through Rcd's and if neccassary they should be put through a 100mA TD Rcd. I was called out tonight to a customer. She has had some building work done and the builders electrician has fitted a 17th edition board with two RCD'S so Oven is on one of these RCD'S but it is occasionally tripping RCD out. She was told by electrician that fitted board that the element needs changing. I tried oven this evening and it got up to temp without tripping RCD. All i could say was that if i had fitted board i would have fitted RCBO rather than RCD. I could replace element but this would not guarantte RCD would not trip out. Oven is 6 years old. I do not no what the answer is. When i do new installations and rewires i shall be putting cooker circuits through metal conduit.
Batty
Batty
