Anyone know of a supplier?...
Long story, can be an "ordinary" response characteristic, i.e. Type A IIRC?
RS have stock.... apparentlyMcb would be 63A 10kA Canoe
Soulman, that is one of my concerns also in looking into this situation.
Seems it's a big NO from Merlin technical on this with this, I'm guessing, simplistic comment, I asked my Schneider supplier and this came back:batty,
Not sure about Protek kit TBH!
However, it does seem they do them.
Do they do a full range of boards & breakers etc. also?
Remembering that the clients I have, have strict specs, so I would need to get the kit "passed" by them.
Noz,
Thanks, I could not find these on the MK site!
Canoe,
I must confess I have a mare with anything on the Siemens site, I find it so hard to negotiate, but, it was the add on type that I thought would be the most likely after the Schneider..
I went for the Schnieder "vigi" first, but could not find a 30mA S type.
Sounds similar then to the Merlin/Schneider Multi 9 "si" type? I use these for exactly the same issue i.e. on inverters:Canoeboy said:Siemens do them - Have asked for a price on a 2P and 3P unit
They do not do an S type as these are only 100,300mA etc as per above posts
They do a Super Selective K (30mA) type which is a time delayed (in essence exactly the same as an S type) and has a 10mS delay - ignore any faults on switch on
They are a Type A and I have used them in the past for 30mA protection of inverters where there is an EMC filter (they aint cheap though :innocent )
No, I don't believe it is time delay per se. Think it is selective in that it "ignores" transients etc. I used them to guard against inverters being a bit leaky by nature on startup. I was posting up on the back of your post #17 where you mentioned using selective units with inverters if I read that right? Not 100% sure what the OP wants the RCD for tbh but wondered if the SI would assist. Cheers.Canoeboy said:Im not familiar with Schneider but are you sure the SI range is a time delayed ?
