not sure measuring resistance would help, its all soldered together so you will get a reading on all pipes, the difference between them will be barely different from the next pipe
Very true, forgot about the big wedge of copper binding all these pipes together...not sure measuring resistance would help, its all soldered together so you will get a reading on all pipes, the difference between them will be barely different from the next pipe
Yeah forget that then, just wanted some electrical tests.not sure measuring resistance would help, its all soldered together so you will get a reading on all pipes, the difference between them will be barely different from the next pipe
I also have to put a door back on, and two cupboard sliding doors. I'm pretty good at dismantling things.Yeah forget that then, just wanted some electrical tests.![]()
Luke, best get the floorboards and carpet back down before you second pair of ears gets back.
anyway, out of interest, why did you join and electrician forum and ask a bunch of sparkys how to fix a radiator instead of a plumbing forum?
I googled plumbing help - and this was one of the top few other than paid responses. I didn't read much into the fact it was on an electricians forum!anyway, out of interest, why did you join and electrician forum and ask a bunch of sparkys how to fix a radiator instead of a plumbing forum?
House is back in working order, minus a door and a working radiator
This was my logic, I've excavated some wall to get full access to the manifold, much to the horror of the Mrs.So with this manifold that you have found....
Is it touchable.. by hand or accessible with a laser thermometer?
If so...
Before cutting anything..
Fill the heating system back up again..
Crank it up high.. make sure all the other rads are getting nice and hot...
Then check the temperate on each of the manifold pipes...
If one is a blocked one with no water flowing, then theoretically is should be much cooler than the rest???
I think ??
opcorn :C
Could well be, I'll see what I can grab.Could it be metal, specifically ferrous metal from inside the rads?
Neodymium magnet!
Or coat hanger with a fish hook shape on the end?
8mm is tight though!
