look in 5 or 9 at the wall with 8, if they head that direction then thatll be where it is
Boiler is bottom left of 4 and pipes go straight up. I’m going to check top right of 5 this evening.where is the boiler? I would think the two 22mm pipes go straight to the cylinder cupboard from the boiler (probably via where cat sleeps) then the flow pipe splits using one 3-port or two 2-port motorised valves. One flow pipe going to the cylinder for hot water, the other going back down under the floorboards to the manifold. See if you can see which way this flow pipe goes, it might save you lifting floorboards in the wrong room
Currently on the case in the top right corner of room 5, found some of the sneaky buggers here.
Will continue destroying neat carpet laying...
Yes have downlights fitted throughout, the nasty 12V kind, each with their own transformer. I'm about half way done converting them to 240V LEDs.do you have downlighters in the ceilings of the ground floor? Sometimes it is easier to pull down a fitting and have a look rather than lifting floorboards. you can get your phone up in there too and take pics of areas you cant see directly.
Take care pulling down fittings, the clips bite. And as this is a sparkys Forum, switch off the lighting circuit at switch and fuseboard.
This is approximately 3.5 metres away from end of blocked pipe.those are the manifolds, flow and return for downstairs rads, excellent find inspector.
Not seen any like that before. Instead of spiders, they look like octopi, (or sextopi?) and the spare ends look like they have been capped with putty.
Are they 3.5 meters pipe run from dodgy rad valve?
