- Jun 21, 2008
- 17,017
- 43
I liked XP don't remember if there was an on screen ket=yboard tho!nah i use xp the best there is
ohhhhI wouldn't put a jint in the cable .
so how you typin these posts if no keyboard?there is a slighty esir way. will post when i get a keyboard.
see #19 & #21so how you typin these posts if no keyboard?with your nose???
Shall I put a keyboard up for sale on TEF??? ] ] ]
yes yes yes Apache!! X(see #19 & #21Admin 2 has confiscated it. He's been a bad administrator. She knows how to hit him hard :|
:^O :^O:^O:^O:^OohhhhDon't think Id put a JINT in either...
you never know what then JINTs will do
We've all been there, that's what apprenticeships are for, and a van load of come in handy bits for when we still mess up occasionallyI had today off work so thought I'd get a few odd jobs tidied up - I installed an extra socket nice and successfully (socket tester says polarity ok and earth present, and there's electricity there).Now my first 'incident' was down to my own stupidity. I plugged my socket tester into the socket I was going to take my feed from and all the lights lit up. I went down and turned off the MCB and removed the socket face-plate. To be 100% safe I tested with my new voltage tester - and it showed 50V and buzzed. So I got my Maplin multimeter out and it read 0V. I was pratting on for 10 minutes when I remembered the new tester was reading continuity! Blushing
After that my gf has been on at me to run a co-ax supply from the sky box to the bedroom. After my success, and since I had the house littered with tools I decided to get on with it. The house has 2 1/2 foot thick stone walls that take a bit of drilling, so out with me 6kg SDS and 1m 12mm drill bit. Hole 1 completed uneventfully. Now to drill out behind the TV I went 10-15cm to the side of the existing Sky cable.What I managed to do was emerge on the other side of the wall IN THE SAME HOLE!
Severing my sky cable in two . This was 6pm this evening so builders merchant locally closed, so I drove to B&Q - 45 mins away. Gathered up a waterproof enclosure, and discovered that they don't sell such a device as a Co-ax cable joint! I cobbled it together with connector strips and insulating tape housed in a waterproof enclosure. Took me about 3 hours to get back to where I was when I started Blushing:O
Was my fun afternoon
Applaud SmileyWe've all been there, that's what apprenticeships are for, and a van load of come in handy bits for when we still mess up occasionally
Mine too - must sort it out............That is why my shed/workshop, is so full Specs.
you boys got to be more ruthless!Mine too - must sort it out............
yes, but up here you now have to get permits to take a trailer/van to the tip. probably because of people like me taking loads of rubbish there. even tho it was 90% personal waste from home.A trailer can be good for taking rubbish down the tip! ; \
:^O :^O:^O:^O:^O:^O:^O:^O:^O:^O:^O:^O:^O:^O:^O:^OHey all,I've done something just as daft and even dafter.
I was doing a rewire and whilst drilling through an outside wall from the inside out the drill bit became lodged and the chuck just kept torking, So I took the drill off the long bit and with out thinking gave it a good whack with my anti-vibe hammer!
'Smash' went the car window as the bit flew through the wall and into the parked vauxhall astra! Oops
always the same, as soon as the drill bit gets thru the wall, its away!. maybe you should make the end of brill bit wider so it doesnt happen....'Smash' went the car window as the bit flew through the wall and into the parked vauxhall astra! Oops
Applaud Smiley:^OHey all,I've done something just as daft and even dafter.
