Acronyms for the electrically challenged
polarity
Jul 10, 2009
62
As a non professional Sparky but with more than a passing interest, I am really enjoying these forums. One thing that I do find a bit of an issue is all the Acronyms - some of which are industry specific and some of which are just "short for" on the board. Not being one to complain and do nothing about it I thought I would start a list.
This is designed to be explanatory rather than technically comprehensive or exact. There are bits missing and vague that I hope people will add to and correct. Otherwise hope someone find it useful.
AC - Alternating Current Normal household electricity
AFAIK / AFAIAC - As far as I know / As far as I am concerned.
BC - Building Control
BCO - Building Control Officer
BRB - big red book (17th edition guidance)
BS7671 - This is the current wiring regulations now 2008 and commonly known as the 17th edition.
BTW - By the way
C&G - City and Guilds
ccts - circuits or certificates
CCU - Cooker Connection Unit
CPC - circuit protective conductor, Earth, ie the yellow and/or green wire
CPD - Circuit Protective Device
CSA - Cross Sectional Area -"size" as in CSA is/isn't important i
CU - Consumer Unit the thing usually next to the meter with all the electrical switches in it.
DB - distribution board
DC - Direct current what comes in and out of a battery, and some, usually low voltage, devices
DEI - Domestic Electrical Installer yer household electrician.
DI - Domestic Installer
Apache
Cow Fiddler ™
Jun 21, 2008
16,997
26
Good man!
SSO - single socket outlet
DSO - double socket outlet
TP - three phase or triple pole
ELECSA - another friendly certifying body
sparkss
DNO Jointer
Mar 24, 2008
143
CPC - circuit protective conducter
Ze - external loop impedance... (Path that earth fault will take back to the star point of transformer)
Zs - eath fault loop impedance... (Path of earth fault back to main earthing point)
R1+R2 - value of phase and cpc linked together while testing
Guiness Drink
and not forgeting CN - Central Networks :p :coat
NozSpark
Seaman stains™
May 28, 2008
12,297
109
North Wales Riviera
Very good, here are some minor corrections & some additions
AC - NICEIC approved contractor
DI - Domestic installer
IEE - Institute of electrical engineers (now the IET)
Part P - Building regulations which apply to all domestic electrical installations, all work comes under these regs, but only some types of work are notifyable
Part P - Qualification.... there isn't one really, although some training providers are doing this type of course which is described as an entry level qualification for scheme membership.... you still need to have an annual assessment by a scheme provider
Ze - the resistance of the line/earth from the consumers connection back to the generator/local transformer (inc the transformer windings)
R1 - the resistance of a circuits line conductor
R2 - the resistance of a circuits earth conductor
Zs = Ze+(R1+R2)
r1 - the resistance of the line conductor in a ring circuit (end to end)
r2 - the resistance of the earth conductor in a ring circuit (end to end)
rn - the resistance of the neutral conductor in a ring circuit (end to end)
Apache
Cow Fiddler ™
Jun 21, 2008
16,997
26
There's NAPIT too
Worth noting that phase/live/line are synonymous!
OSG - on site guide
MFT - Multi-function tester
IR - insulation resistance
IP** - ingress protection, followed by 2 numbers
spinlondon
Distinguished Member
Apr 18, 2009
1,388
Not to forget:
CCU Cooker Conection Unit
CPD Circuit Protective Device
FCU Fused Connection Unit
SCU Switched Connection Unit
SFCU Switched Fused Connection Unit
MEBC Main Equipotential Bonding Conductor
MET Main Earth Terminal
PEN Protective Earth and Neutral
PME is Protective Multiple Earth, which I think you'll find is the new TN-C-S
RCCBO Residual Current Circuit Breaker with Overload protection
RCCD Residual Current Circuit Device
RCD Residual Current Device
With TT, TN-C, TN-S, TN-C-S and IT. The T refers to Terra (Earth), so TT is basicaly Earthed Earth, TN-C is Earth Neutral Combined, TN-S is Earth Neutral Seperated, TN-C-S is Earth Neutral Combined then Separated and IT is Isolated Earth.
TP&N Three Phase & Neutral
Pyro
Feb 27, 2008
136
MIMS - Mineral Insulated Metal Sheath. See also MICC. See also Pyro.
PYRO - Abbreviation for Pyrotenax, a generic term for the MIMS / MICC cable type.
Feb 27, 2008
11,020
This trade must be the worst for using all these acronyms , then just as you get used to one ,they change it ( PME = TNCS You need to speak Latin to find that T stands for Terra =earth ) Or new ones appear from nowhere , I think what the hell is this guy waffling about , such as MET , Main Earth Terminal apparently , Itend to call it the Main Earth Terminal !! What I call an earth wire others call a CCP now. We used to check loop impedance now its called Zs . Don't even start me on the organisations attatched to the trade.
ECA , JIB, EEPTU, IEE, NICEIC, ELECSA, NAPITT , Oh! SODITT, they go on forever.
Don't forget the most important one BSI.
:D
