Evening Guys.
Ive just been to price up some work at a b+b. They have an outbuilding with one b+b room supplied from main building via 6mm t&e on catenery wire. This is way too small as running elec shower, heating, sockets, and immersion. So needs to be replaced. Looked in the main cu / meter area and found a few faults.
Bare in mind this work detailed below was carried out 9 yrs ago.
Supply is TT with 25mm tails. Meter - old school ELCB - henley block. Tails are then split to 16th ed split load hager and a metal clad wylex sw fuse that supplies a second db (via 16mm t+e) for b+b rooms. Present supply to outbuilding is from rcd side of hager. On the non rcd side of the hager is the lighting for b+b, this is relying on the elcb for protection.
Now im only working on the rcd side of the hager, so technically im covered rcd wise for the supply.
What would be the best way to deal with the other problems / would i have to as im not working on them?
I was thinking of replacing the elcb with a 100mA type s. This would help with the metal clad sw fuse but would i have to 30mA rcd after the sw fuse to cover for the 16mm T+E. The cable runs under floors and in walls. The lighting in the hager, was thinking of rcbo`ing the lot.
Again though. As im not working on the other stuff am i obliged to sort it, whats your thoughts?
Cheers
Chris
Cheers
Chris
