- Feb 10, 2009
- 342
- 18
Hi. I need to pull some cable through 20mm PVC conduit. The configuration is quite convoluted but I'm hoping I've put in sufficient boxes (every 2m or so) and kept bends to a minimum. The max number of cables thru any section is 6 x 1.5mm plus 3 x 2.5mm. According to my CableMate calculations 20mm should suffice.
Previously I've only ever done this in a college workshop bay, on a very small scale.
What I'm asking for is some general advice e.g. should I pull all cables thru together or not?, Should I attempt to pull thru all boxes in one pull or break it down into small runs? whats the best way to apply cable pulling lubricant? that sort of thing.
Thanks in advice for your time.
