- Nov 28, 2009
- 14,670
- 827
So the fact it is not CE marked makes it illegal to sell.It's not ce marked. It's Chinese export
Well, a lot of people also upgrade all the wiring in the house (or at least for the audio circuit) with a separate CU installed too - and with upgraded fuses:
https://highend-electronics.com/products/synergistic-research-black-quantum-fuses
I think what @Sidewinder is pointing out, and I come across it more than I like in control panels. Is just because it has a CE mark doesn't mean that it meets the requirements to fulfill CE.
In effect they've just slapped a marking on it, they aren't complying to relevant standards. Unfortunately there is no law for the company to provide users with the CE documentation, they only legally have to provide it to the HSE or trading standards when they get involved.
Don't believe all you read on Wikipedia, however, in this case, it is pretty close to the truth as far as the EU see it.I'm not sure; I read this on wikipedia:
A logo very similar to CE marking has been alleged to stand for China Export because some Chinese manufacturers apply it to their products.[19] However, the European Commission says that this is a misconception. The matter was raised at the European Parliament in 2008.[20] The Commission responded that it was unaware of the existence of any "Chinese Export" mark and that, in its view, the incorrect application of the CE marking on products was unrelated to incorrect depictions of the symbol, although both practices took place. It had initiated the procedure to register CE marking as a Community collective trademark, and was in discussion with Chinese authorities to ensure compliance with European legislation.
Incidentally, if you zoom in on the picture provided by rapparee, I think the CE mark on the socket looks more like the standard CE on the left than the Chinese Export symbol on the right.
According to this site where this particular item is installed:
http://singaporehifi.blogspot.co.uk/2011/05/furutech-fp-1363-uk-ac-outlet.html
Each outlet has an independent terminal - the terminals of each have to be jumpered together if the outlet only has one set of wires. I.e. if it has 2 sets of wires, then one goes to each terminal and they do not need to be jumpered.
If it works fine now with no issue - under what circumstances might it become a problem?
Excellent replyWell, perhaps a counter-analogy might be this: water may travel for many miles to your tap, but adding a filter to it can still remove impurities.
