tsrplatelayer
- Joined
- Nov 12, 2013
- Messages
- 4
- Reaction score
- 0
I have just commissioned a new piece of furniture. It will completely fill the alcove and I want to bring the sockets to the front of the cabinet. I initially intended just to use a commercially available extension, plug it in and mount on the front of the cabinet. With an access hole in the back of the cabinet to access the socket and switch on the wall.
However this would spoil the look of the cabinet. instead I want to fit 3 * twin 13A switched sockets mounted into the cabinet frame in plastic patress boxes. These will only be used for low power devices so overload is not an issue.
So to my questions
1. Connecting the 13A sockets together - 1, 1.5mm or what twin and earth solid core?
2. Connecting the sockets on the front of the unit to the wall - is the use of a plug OK? If so what sort of wire? If not a switched fused spur - but that would be very difficult to access to change the fuse in future - hence the preference for a plug on a flexible wire which, made long enough, could be pulled forward through the cupboard to access the plug to change the fuse.
3. Is certification/testing required on the finished cabinet/wiring?
Obviously this should all be assembled by someone with appropriate quals!
Allan
So to my questions
Allan
