I am putting in a 9.5kw shower to replace my old 8.5kw, i am correct that the old 6mm cable will need
replacing with 10mm cable on a 45 amp mcb in fuse box (old type) and a 45amp rcd between the run
from shower to mcb ?, the cable run is in conduit up to ceiling, under floorboards then bare up to loft
into conduit again down to shower so there will be volt drop ?, total cable un is approx 18 metres.
Am i allowed to do this, providing i get a qualified part p registered professional to test afterwards .
sorry i meant AM I CORRECTBrainless said:I am putting in a 9.5kw shower to replace my old 8.5kw, i am correct that the old 6mm cable will need
