There is no such thing as a reset code. It's a myth. The is a 'default' procedure that will reset the panel to it's default settings, including both user and engineers code. PLEASE NOTE: on these panels the engineers' code can be locked in the panel setup. If this option is active then there is no way to reset the engineers code without sending the panel back to texecom and by the time you ahve paid to do that, you might as well have bought a new panel. The default procedure by the way is in the installation manual.
