If its a house alarm ( stand alone) don't worry about helicopters and the plod, as The Hornet said, you need eng. code and some 4 core signal/ alarm cable, make sure you check the colours used.
Deke
Deke
How did the alarm send out a signal when the power was turned off if the battery did not take over ?I had one when I turned a circuit off to change a socket it was in the evening and within ten minutes the police turned up. Anyway the alarm company had not changed the battery on the previous service which had only been a few months before. The alarm had sent out signal as the battery had not taken over, luckily the customer was there and told them everything was ok. Some of these alarm companies take the money but don't give a service.Batty
It was wired into redcare or whatever its called.How did the alarm send out a signal when the power was turned off if the battery did not take over ?
