Am I expected to be competant in Extractor fan installs as a bs7671 electrician?
Feb 14, 2021
110
21
Whitby
Hi yall,
A customer I have quoted for seems to expect that other than installing a 230v feed/supply for an en suite extractor fan, as an electrician, we are supposed to plumb in the outlet, tie into the existing vent and/or do the necessary brickwork removal, sealing and tile work etc.......Since when?
In the whole bs7671 regs book, there is absolutely no mention of extractor fans - at all. (not that I was expecting there to be)!
As an electrician, we adhere to Part P of the building regs where as ventilation is part F.......
Ill certainly at least research and probrably do a cpd or 3 before choosing whether or not to take on the job as a whole.
Where does this expectancy come from anyone?
Cheers n stuff
Leigh
It is up to you. Personally I only do the electrics. Last one I did recently I put the fan in the ceiling, wired it, and left the outlet hose ready for the roofer to come, fit a vent tile and attach it. This was agreed with the home owner before i started the job. If the owner had not agreed she would have been looking for a different electrician.
Cheers for the replies chaps.
Yeah Ive just been to another job and ive now got 3 to fit and 2 to repair/fault find in total now.
Ive done a few cooker hoods before so will be fine im sure. Luckily just bought a new 117mm core drill too.
It was just the expectation that I would do it all that threw me a bit.
I guess clear communication with the customer is key if some other trade needs to finish the complete install.
Any brands you favour?
I try to avoid the building work as such, but have done it many times. Easier options for an upstairs bathroom is a ceiling fan and vent in the soffits. Core drilling, once the pilot drill is through you can do that from both sides, this avoids blowing lots of external render off , or chipping out the brick edges, so keeps internal and external edges clean. Not my favourite job. Once you have core drilled both sides a few inches, it's sometimes easier just to use a chisel bit, core drilling is ruddy slow.
decent core bit & drill and you'll get through easily from one side. i don't use a pilot bit either
im also lazy, drill all the way through from inside, throw rope through, attach rope to vent with plenty adhesive / silicone on, use rope to pull up and into place from inside. no need to get the ladders out and no working at height
since most of us are capable of doing the full job and not limited to just sticking a few wires into terminals and getting someone else to do most of the work
Our survey says 51% then........therefore most of us?
I have a point though as electricians are part P not part F..............
Like it..............................
found this - https://www.efixx.co.uk/envirovent
Pilot bit is not needed once you have the hole started. Round here we have quite a few cob walls, so could hit slate or granite stones, or both. Most houses are also rendered - a by prouduct of the China clay indusrtry means lots of silver sand was available cheap, and rendering is popular becuase of the rainfall. So you start off hard render, then hit lumps of granite / slate and ancient mortar, then hard render again - right pain in the neck, and easier hit from both sides! And just for fun, halfway through the wall a lump of granite falls down and jams the core..🤬
wow, sounds fun................ i remember a few encounters when core drilling through for a cooker hood, then once the core drill bit is removed it was like a snow globe with all the cavity wall insulation wanting to escape. A few tesco carrier bags sorted the problem........
i don't even use pilot bits to start the hole. partially because mine can't take a pilot - they have built in extraction using the centre bore so a pilot bit doesn't fit in
easiest way is i have a piece of wood with the relevant core size hole in it. the wood is screwed to the wall and you can use that to start your hole. and if you have the holes in your wood in the same place as the fixings for your fan, then you don't need to drill any more fixings holes since they are already there
or you can just kinda hold the core on an angle and start it that way. its messy and exact starting point will vary from where you can it, along with chewing up some of the wall, but if its being plastered / tiled etc later then that doesn't matter
probably worst one I've done, wall was about 800mm thick. mix of stone, cement, other shite etc. core drill went through and cut no problem at all. the problem was getting in far enough to break out the bit that's been cut, so that the core drill could then get further in and keep going
Most SDS drills have a clutch. I discovered mine has one when a long drill bit (not a core) jammed and I thought it had stripped the gearbox, but it was just the clutch slipping so the drill was not wrenched out of my hand.
