As far as I can see , Amd 3 , reg 421-1-201 asks for consumer units & similar switchgear assemblies to be made of fire resisting material . Then shows a preference for steel .
So , is a domestic isolator switch similar to a consumer unit we ask ourselves ?
After 500 years in the trade I look at the two , side by side , and I think , this 100A DP isolator is nothing like a consumer unit whatsoever . Its enclosure may as well be plastic , the same as the DNO cut-out . ( Which used to be steel BTW :C )
Again typical of this country today , jump in with stop gap solutions without applying logic .
Picture the scene ... a man arrives at 221B Baker Street with a consumer unit under his arm.
Holmes : " I see from your strange attire that you have travelled back from the future, how can the good Doctor and I be of assistance?"
Man : " My dear Holmes , we have been fitting these units for 60 years and suddenly they are going up in flames .
What are we to do ? Should we start building them from steel to contain the fire?"
Holmes: " These boxes of plastic you speak of have been fine for 60 yrs ... so the cause is not with material my good man "
Man : " Then what can it be , some deadly plot by Moriarty , some great ghostly hound chewing the cables ?"
Holmes : " It is a one pipe problem , logic dictates there are two possible causes , (1) The devices inside the mysterious boxes
are not as they used to be or (2) The artisans who fit them are incapable of tightening up a screw .
To consider the problem to be caused by the case itself is a total nonsense Sir . "
Watson : " Again you amaze me Holmes !!"
Holmes: " Elementary my dear Watson . Now Sir , take yourself back from whence you came ...and by the way ...your magic box
will never replace gaslight "!
