- Mar 28, 2008
- 14,509
- 1,187
As title...
How many and why? :|
:coat
:coat
:^O :^OApplaud SmileyApplaud SmileyYou can, but only if the requirements of 1.2.3.4.5.6 vii are met fully
You are of course quite correct there Patch.You can, but only if the requirements of 1.2.3.4.5.6 vii are met fully
Bottom of page 234582.34.7.1The Yellow shall not be sleeved Black, unless the CSA of the line conductor is equal to the square root of the MCB breaking capacity.
The following exclusions apply to TT installations,
(i) SWA run overhead clipped with sky hooks need not be sleeved.
(ii) MICC run vertically up lift shafts shall only be sleeved Blue on a Wednesday.
(iii) RCDs rated 30ma or higher shall only be used where they are needed.
So I think that has cleared that up!582.34.7.2All cables immersed in water at a depth of 6m or greater, must included PME Earth stakes to all conductors, crimped, soldered or compound filled, or screw terminal with anti-clockwise thread. Other methods are not precluded provided equivalent mechanical bond is achieved.
The request forms are in Appendix v. You need to fill them in in triplicate, send one to Admin, one to the pharmacist and eat a copy.
