D
Dane
Guest
[quote name='Andy
Sounds like you've had some practice nicking car** Update ** - And I feel A fool for this, as it happened to me a Month or two Back and I forgot about it asa possible fault...Talking to My Wife's friend down the school this morning. (The one I mentioned in my post on this thread).
She had an Auto Electrician out and it turns out that it WASN'T the ECU - BUT...
The Ignition. The actual plastic bit that the Ignition barrel goes into.
This happened to me when I changed all my door locks and Ignition Barrel.
The new ignition barrel, I would be able to start the car one minute - then cut out - leave it and it would start - tick over and cut out again, then it wouldn't start at all. It also had a full range of ignition lights and on the 3rd (start) click position, all the lights would go out and... Nothing.
Andy, Take your igition barrel out - and try a Flathead screwdriver, carefully on the plastic 'X' shape - the the igition barrel slides into, and see if it starts.
Let us know mate.
I hope that it is this as it will be a Heck of a lot cheaper than an ECU etc.
Good Luck.
hi Badger,my dads car has gone into the vauxhall dealer where he purchased it from with the same symptoms that you have andy and the tests that came back where something called a sim neds to be ordered and changed so thats going to be ready for monday morning for im, im asuming its a sim card or something, but not sure, it could be something similar thats wrong with your car??
i dont think it is this. a while back when i did change the filter and didnt put lid on properly, it wouldnt start, exactly the same as it wont now. but when i do remove lid/stop fuel, it slowly struggles for a few seconds before cutting out. with this fault, it cuts out immediately as though youve turned the engine offhia blocked fuel filter never gives a code, like running out of fuel:coat
Most likely the battery by the sounds of it. As a rough guide the readings should be around;My turn for car problems. (Cmax diesel 1.6 04) went out a few days and tried to start - flat as a pancake, jump started from sons car. left running for a while to recharge. next morning same story. This time drove it for half hr. This morning it started perfect. Measured battery voltage after the first time it did it and it was 14V with engine running and 12.8 and dropping when I turned it off. Looks like I may need a new battery soon or perhaps been on too many short journeys with lights/AC/heated screen on perhaps
