[SIZE=medium]Hi All!! Hope someone can help!!!![/SIZE]
[SIZE=medium]Now then, I have a welding set, a modern inverter type with electronic control by means of a PCB. Output current for welding is controlled by means of a pot used as a voltage divider to create a signal in the following manner. A voltage from one terminal of the PCB, feeds one end of the track of the pot which is then, in turn, led back to another terminal of the PCB. Another wire connected to the wiper of the pot also leads back to the PCB to provide the control signal..[/SIZE]
[SIZE=medium]There is a changeover switch incorporated, which allows you to switch this pot out of circuit and switch in another one on the end of a cable, for use as a remote control[/SIZE]
[SIZE=medium]Now here is the problem…..[/SIZE]
[SIZE=medium]I bought a remote control for the welder, problem is, the pot in the remote is not the same value as the one in the welder itself….[/SIZE]
[SIZE=medium]The pot in the welder is a 2k2 one, and the one in the remote is a 4k7 one…. The supplier of the remote assures me this is not a problem and it will still work ok, but I am not so sure..[/SIZE]
[SIZE=medium] I know that when used as a voltage divider the value of the pot does not matter up to a point, but, pot value WILL affect the output signal voltage from the wiper depending on load current. Sooooo….[/SIZE]
[SIZE=medium]Here are my questions;[/SIZE]
[SIZE=medium]1, As both ends of the pot track are connected to the PCB, could use of a different value damage the PCB by forcing it to provide a higher voltage or whatever??[/SIZE]
[SIZE=medium]2, What sort of current value will the control signal from the wiper to the PCB need to be?? Will this be low enough that pot value does not matter??[/SIZE]
[SIZE=medium]3, What is liable if anything to go wrong if I use the larger pot?? Could I damage the PCB in any way??[/SIZE]
[SIZE=medium]4, I assume that the makers used a 2k2 pot for good reason and did not just pluck a figure out of the air, would I be mad to fit a different pot??[/SIZE]
[SIZE=medium]5, I cannot find any markings on the pot in the set, at least not without taking half the welder apart. Is there much of a correlation between pot size and wattage?? The "body" of the pot in the welder is about 15mm square and about 8mm thick. Can I guess pot wattage from this??[/SIZE]
[SIZE=medium]6, If I need to get a new pot, what is the best sort for long life and stability and general being right for the job, a carbon track one, or a wire wound, or a plastic film, or cermet one or what??[/SIZE]
[SIZE=medium]I know very little about this sort of thing so I hope someone can help…[/SIZE]
[SIZE=medium]Thanks all[/SIZE]
[SIZE=12pt]john[/SIZE]
