Any idea what this is, growing in an electrical enclosure?
schaffs997
Oct 2, 2023
3
Preston
Non-electrician here. I'm looking to pick the hive brain and wonder if any of you have come across anything similar to the growth in these pictures - this was found within a sealed electrical panel located within a manufacturing environment. Any ideas what it could be?
When you say "sealed electrical panel" how sealed is it
What type of plant is this panel on looks like it could be dust / particle ingress from a manufacturing process
Cheers for the replies so far - its an aircraft manufacturing plant - pretty clean environment with no airborne dusts etc. The cabinet is sealed as in ATEX rated - though not sure of the spec.....its deffo a weird one
From the even distribution on varying surfaces and materials it looks to me to have been sprayed with a fluid which has subsequently supported some sort of fungal growth. You need a chemist. I would treat it with respect, whilst unknown, as some fungus spores are harmful.
Thanks Geoff - that's the thinking- and next port of call. I've spoken to a few people and no-one seen anything like before.
Can't help thinking whoever installed the board had very sweaty hands. I have seen something like this in a solar inverter with a slight leak. Damp and heat had cuased fungal growth inside the inverter and a lot of corrosion.
Would definetly get it analysed though, you can get some pretty poisonous compounds under such circumstances.
I'm also non-electrician! The only thing I've ever seen that looks like this is a hoar frost which I once saw formed on the inner roof of a tent, would seem extremely unlikely to me though given electrics usually generate some heat and also you don't mention any refrigeration. best of luck solving it...
Thanks in advance. View attachment 16155View attachment 16154
This factory; Is it smelly in there?? Are there large temperature changes or is it humid in there??
john..
WARNING.. I downloaded one of the photos this morning and when i went to open it the program said that it could not as the file was too big..
An hour later i did a virus scan which detected a zip file containing my first ever virus..
Coincidence????
john..
It looks like a white mould/fungus. If by chance moisture got in before the panel was sealed. If the panel get warm while in operation and cools when off, this will create the right environment over time .
