schaffs997
Can't help thinking whoever installed the board had very sweaty hands. I have seen something like this in a solar inverter with a slight leak. Damp and heat had cuased fungal growth inside the inverter and a lot of corrosion.From the even distribution on varying surfaces and materials it looks to me to have been sprayed with a fluid which has subsequently supported some sort of fungal growth. You need a chemist. I would treat it with respect, whilst unknown, as some fungus spores are harmful.
This factory; Is it smelly in there?? Are there large temperature changes or is it humid in there??Non-electrician here. I'm looking to pick the hive brain and wonder if any of you have come across anything similar to the growth in these pictures - this was found within a sealed electrical panel located within a manufacturing environment. Any ideas what it could be?
Thanks in advance. View attachment 16155View attachment 16154
