It trips with or without the light on.So the new fluorescent is on the 1amp MCB which trips? Have you tried isolating that?
It can easily be sorted out even if the parts are not availableturned out ( see what I did there?) to be the brake unit coil cooked. trouble is they are like gold dust so lathe might be finished if they cant get one!
looking at a local rewinder repairing it.It can easily be sorted out even if the parts are not available
The power supply in the bottom centre of the panel is for the brake unit. Brake coil is cooked, no information available. Getting one made but they need to know voltage. PSU for brake is fed from a 73V winding on transformer which also provides 110v control voltage for rest of machine. I measured 68V dc on the output of the PSU with the brakes off (no coil attached) 68V seems a rather random rating never seen one like that before. I could have believed 48V. Machine is a Harrison M400 would really appreciate if you could advise on coil voltage.Yeah I have worked on suchlike
Thanks Geoff, not about to pay for a manual, I'm not SE so its up to the owner. I am thinking the semiconductors are some kind of voltage regulator. The power supply has AC on the input side all the time and only when the lathe is running does the DC side kick in to release the chuck. It would be useful to know what the coil voltage is supposed to be but no way of finding out short of finding another machine and measuring the voltage!I thought "mystery" coils could be rewound just using the weight and gauge of the removed copper.
The concern I would have is whether there is an electronic regulator which has failed short circuit, so increasing the voltage onto the coil and killing it.
Note I don't know anything about lathe controls as such; just guessing and wondering what the semiconductors visible in your photo are for.
Thanks I'll check it outHave you tried the Lathes-UK website?
very helpful when I had an issue with my Denford Viceroy
