To contribute to my own discussion
WHAT IS HIGH VOLTAGE BATTERY SYSTEM?
The high voltage battery systems are usually rated at more than 100V. These powerful batteries can charge and discharge faster than low-voltage ones, making them ideal for covering those quick demand surges from starting equipment that might not be able to stay running without power immediately. The increased volts also mean smaller conductors.
High-voltage battery systems are a more recent development in the world of home solar battery backup. These higher voltage models can provide increased energy output to support heavier loads, making them perfect for homes with electricity consumption rates that exceed what is typically seen at lower voltages
Commissioning a home battery backup with an high-voltage battery not only increases efficiency but also saves energy. The DC bus voltage normally varies between 300 volts and 500 V, so when you choose this option your inverter has less work to do. When you choose a low-voltage home battery backup, the inverter needs to work harder and reduce an input voltage of 300 -500V below 100 V. This results in less energy efficiency for your home or business’s power requirements.
High voltage battery systems are perfect for properties with commercial energy storage demands and home battery backup use. They offer a number of advantages over other types of batteries, including longer life and higher discharge rate. In addition, high voltage battery systems are less likely to overheat, making them safer to use. With their many benefits, it’s no wonder that high voltage home battery backup are becoming increasingly popular.
THE HIGH VOLTAGE HOME BATTERY BACKUP ARE MORE EXPENSIVE TO INSTALL?
Generally speaking, the price of
high-voltage batteries in the market is higher than that of
low-voltage batteries. The main reason for this is the high manufacturing cost of high-voltage batteries and the brand premium. However, there are a number of factors that can affect the price of lithium batteries, including the type of battery, the size of the battery, and the quality of the battery. In addition, lithium battery prices can also vary depending on the supplier. As a result, it is important for buyers to compare prices from different suppliers before making a purchase.
Source:
https://www.bonnenbatteries.com/hig...hats-the-best-choice-for-home-energy-storage/
Another interesting post
https://www.deegesolar.co.uk/high_voltage_or_low_voltage_solar_batteries/HIGH VOLTAGE BATTERIES
High voltage batteries are a recent phenomena within the solar industry. Compared to LV batteries, high voltage
solar batteries offer a higher discharge rate to support higher load demands. High voltage battery systems are usually rated around 400V. These systems can charge and discharge faster than the low voltage batteries and can cover those quick demand surges from starting equipment. If we take this back to the water tank analogy a High voltage battery is a high “pressure” battery. Which means as the pressure in the battery is high, as soon as the battery is switched on there is a burst of initial energy, resulting in a quicker discharge of energy or water from the hose. Because the voltage is so high in a HV battery, they do not require larger conductors.
In a high voltage battery system, the inverters tend to allow for less battery connections (around 3 batteries), however the individual batteries themselves are much larger in capacity. What’s more, when commissioning a
home solar PV system with a high-voltage battery you can increase the efficiency of the entire system. This is because the DC bus voltage is normally around 300-500V and the current running to the inverter from the battery is significantly lower. In contrast, when you choose a low-voltage battery, the inverter needs to work harder to reduce the input voltage of 300-500V to below 100V. This results in a loss of energy, and a less efficient system.
High voltage batteries are perfect for households or commercial properties with exceptionally larger energy demands. So if you are looking for faster charging and discharging, a HV battery is the right choice for you.
EXAMPLES OF HIGH VOLTAGE BATTERY SYSTEMS
Here are a few examples of the HV battery systems we install here at Deege Solar.
- The 5.8kWh High Voltage Solax Triple Battery with the 5kW Solax Inverter.
- 2 x 2.6kWh Fox Ess Batteries with a 5kW Hybrid Fox Ess Inverter.
- 5.12kWh Sofar Amass EP HV Battery with a 6kW Sofar Solar Hybrid Inverter.
- HV Batteries have Higher Charge and Discharge Rate.
More Efficient System.
- More Expensive to install.
