I would go for option 3 to keep unnecessary costs down. It would think it's cheaper than the other 2 options as string inverters are quite low cost.
I have just calculated the Max Voc at minimum Temperature for the 400W Panels.
(The layout so far is as followed:
- 13 panels on the main roof,
- 5 on the wall
- 3 on either side of the small roof)
Following the instructions
here and taking -5°C for the expected lowest in Cheshire. It gives 45.23V
As I can fit 13 panels this makes 13*45.23= 588V and the inverter proposed (Growatt SPH6000) has a Max PV Voltage of 550V. So I will have to remove one panel.
This is +1 for the micro inverter.
Alternatively, I could have 12 panels on a string inverter and one micro inverter on the main roof like the rest of the locations.
if I use Tigo optimizer instead. One string will be loaded with 12 panels from the main roof with no tigo optimizer, then the rest (1 from the main roof + 11 panels from the small roof and the wall) with Tigo Optimizer on String 2.
Furthermore, the minimum Voltage per string must be calculated. This is where things start to get interesting.
My worst case scenario is for the panels on the Wall and the small roof + that panel from the main roof). This gives a total of 12 panels but they are facing different directions and there will be partial shading as shown on the pictures above.
Calculating the minimum of panels it gives me 5 panels. This is a problem. This means that there is a risk that too often the 3 panels on the SE small roof will not be enough to wake the inverter up in summer (warmer temperatures). and ever worst. As the sun moves and starts being on the right hand side of the small roof, when the panel on the right starts producing this will not be enough for the inverter. (see sketch below with the shade in the morning)
Tigo Optimizer, if I understand correctly, won't help at all in that situation. I will be wasting sun exposure because not enough panels will be providing enough Voltage.
I am poised to need to go with the micro-inverters option (the most expensive) for the wall and both side of the small roof.
Maybe I missed something and one of you will tell me I am all wrong and there is a better way... Please tell me I am wrong.
Thank you for baring with me and for your patience.
