johnb2713
I'm embarking on a battery build that will be similar in concept to a power wall / AC coupled battery. It has a 5kw Victron inverter / charger, 16 x EVE 280ah LifeP04 cells, Seplos BMS. I have designed a cradle for the cells to group them in 4's, the heavy current cabling being 25mm2 going into Anderson Connectors (175A). I intend to put a fuse in the circuit - 150 amp, my max running current will be 100amp.
My question is with regards to isolating the DC, I can pull an Anderson connector apart on any battery or I can fit a DC isolator which is adding another connection in the circuit. In terms of DC isolators I've seen Automotive / boat ones rated at 200A and above or proper solar ones but only rated to 80A.
This is going outside, on a wall, with heater and cooling fans etc.
Any thoughts?
Any thoughts?
