battery driver
0151
Feb 21, 2009
116
guys i have a dewalt 12v driver drill thats about 5 yrs old now.
when a screw is fully home it now just stops dead instead of carrying on like it used to.
my question is it the batterry thats bolloxed or the drill.
just though you may all know as im skint and dont wish to buy a new battery if its the drill
thx
carl
Sounds like a battery issue, but to be sure pop into a good tool store and ask to try it with one of their 12v battery's.
ok thanks guys
another Q thou
are the no name replacement batteries any good or should i stick to the genuine dewalt ones
One of the diy chains was more or less giving the 12v dewalt batteries away can't remember which one it was though although I think it may have been homebase.
Batty
guys i have a dewalt 12v driver drill thats about 5 yrs old now.when a screw is fully home it now just stops dead instead of carrying on like it used to.
thx
carl
Sorry but to me this appears to be a torque problem rather than a battery.
Check your settings and make sure you have set a high enough torque for the job you are doing.
One easy way to check if a battery is goosed is to run it without any load, or resistance, or check it with your tester after a full load/charge.
Battery as said many times...
battery is coming to end of its life and just cant "power" the drill when its under load.
try to fully discharge the battery by placing it in the battery charger and leaving it un-plugged. then re-charge as normal..
try to fully discharge the battery by placing it in the battery charger and leaving it un-plugged. Then re-charge as normal..
thanks for all the replies guys
i never knew about the above though thanks for the handy tip matt
