BorisJ
All these calculations assume the batteries are 100% efficient, i.e. you get out as much as you put in. You don’t. I don’t know about modern lithium ion batteries but previous batteries the figure was about 70%.
My Victron system runs at approx 93% efficient (energy in to energy out).All these calculations assume the batteries are 100% efficient, i.e. you get out as much as you put in. You don’t. I don’t know about modern lithium ion batteries but previous batteries the figure was about 70%.
Heres today:I get that, but are they paying out more than the standard rate you would have to buy leccy at if your battery is flat if an evening?
Has to be said, it would be good for RoI if you have a larger battery than you need. Sonnen were talking about this years ago, although I don't think they ever really got off the ground in the UK.
Batteries and inverters have manuals of varying degrees of detail.Do the kits come with full instructions?
I told ours of the solar and battery installation, it was added to the building insurance with no increase in premium but a £15 service charge was made.Does the home insurance company need to be notified?
Average UK price is 34p per Kwh according to a quick google, so it would only really be worth selling back to the grid between 16.00 and 18.30. Even then you are down a ha'penny for any energy purchased due to lack of battery stored energy. Every ha'penny counts you know .
Thank you @johnb2713.Batteries and inverters have manuals of varying degrees of detail.
The electrical installation is simple.Thank you @johnb2713.
I want to have all my ducks in a row before I try talking to an electrician to do the job.
Interesting. Roughly how much does that work out per kWh?The EVE cells I've used in my batteries (and the Fogstar ones mentioned) have a predicted life of 6000 cycles, a cycle is fully charged and discharged. Assuming one full cycle per day, that's 16.4 years. A couple of points, the batteries don't fully cycle every day so that 16 plus years is longer and when they're deemed end of life is when their capacity drops to 80%. Even at end of life they're still providing worthwhile storage eg 20kWh would be down to 16 kWh.
See post #3Interesting. Roughly how much does that work out per kWh?
Solar is a selling point these days.btw...the added advantage of having battery storage only...if you sell your home and move...and the buyer won't fork out for your inverter storage system....it's as easy as taking your washing machine or fridge/freezer with you...lol
solar not so easy !!
EVE cells are the best in the field second to none. It looks a tidy unit for sure.@johnb2713
Hi John. I had a look at the Fogstar batteries and liked the look of this:
https://www.fogstar.co.uk/collectio.../fogstar-energy-48v-15kwh-rack-battery-bundle
In the specs, it mentions that these batteries will provide 6000 cycles at 50% DOD, and 4000 cycles at 80%.
I am not sure if all lithium batteries give the same performance. I have not seen this 6000 Cycles @ 50% DOD before... Not sure is something ithe manufacturers tend to hide or not.
what I was intending to point out is payback of solar over battery is much longer if you are buying cheap off peak energy versus peak expensive energy....thats why I wouldn't for for solar in my situation.he 4 extra plyontechs and 6-7 hours of off peak make perfect financial sense. charging at
ahhhh....one of the lucky few .....a lucrative FiTLosing my solar system and FiT payments
Quite right Creaky...sorry...its only a battery system...very nice though with self heating and builyt in DC breaker.....you still need to go from 52VDC to 220 AC using a suitable inverterI assume a standard inverter would be required, without the need for hybrid? This should cost less too.
