Anyone know a readily available alternative MCB ,?
It's got the wide Busbar so an Eaton doesn't fit
Yep, deffo a Talisman Plus.If it is definitely Plus then Memshield 2 are compatible. If it is just Talisman then Memshield 1 but they are no lo get available as a new product.
Ahem!I do believe Our Deke was the master of all knowledge on Bill Talisman, I dare say he’d have had a range of stock. Bless him
Cheers , which particular Eaton MCB will fit,? Is there more than one type,?Memshield 2 which are still available under Eaton will fit. Bill and MEM merged and Talisman Plus and Memshield 2 are essentially the same thing.
Uh oh! I feel a pussycat paw coming my way!Ahem!
PM sent
I need a few different ones, and some RCBOs as well.Yeah thats MEM3 which doesn't fit , the MEM2 as posted by kerch are compatable (and depending on when it was made, might also be badged as eaton as seen in my picture!)
Is it a C10 you are looking for?
Had seen those,The RCBOs on MEM2 were often by a field fit pod that clipped onto the MCBs, still available, but expensive!!
https://www.edwardes.co.uk/products/eaton-mem-mr30-30ma-rcd-memshield-2-add-on-pod-requires-mem-sp-mcb-?gclid=CjwKCAjwuvmHBhAxEiwAWAYj-P1rUP84819Kn1t-wO4XpUlbw_Pjn5R83sVtSWCr2RbSzm5ODbKarRoCf8MQAvD_BwE
Actually MCBs also available new, but at between 20-25 for a single pole device, not cheap https://www.edwardes.co.uk/products/eaton-mem-mch110-10amp-1-pole-type-c-10ka-memshield-2-mcb
