Peter Moffatt
- Aug 22, 2021
- 1
- 0
I have an LPG boiler which I’ve recently had earthed. The electrician has run a cable from my electric meter to a copper gas pipe under the boiler. Is that correct?
You might care when the next gas safe engineer shuts off your gas because HE is not happy with where it is even though the electrician is happy.I dont really care where it is as long as it is where it is.
I still wouldn't care because one thing for sure HE or maybe even a SHE is not an engineer.You might care when the next gas safe engineer shuts off your gas because HE is not happy with where it is even though the electrician is happy.
One I was thinking of, the pipe from the gas meter ran up the wall and into the loft of a bungalow. I bonded the pipe just inside the loft space as close to the entry point as I could reach. Almost a year later I got called back because the gas man had failed it and was threatening to shut the gas off, so I had to do the ludicrous thing of exit the earth cable from the loft, cable tie it to the gas pipe, and connect it with a clamp inside the gas meter box.
I WISH we had a common set of regs to work to for this.
hum…. I just wish that so called plumbers used the guidance from BS 7671 that we use.I WISH we had a common set of regs to work to for this.
Yes but my observation is plumbers expect it to be visible on the OUTSIDE of the property. We on the other hand interpret it as either inside or out.hum…. I just wish that so called plumbers used the guidance from BS 7671 that we use.
600mm where ever practical .
but numptie plumbers ignore the where ever practical and others can’t see 10mm GY cable in front of their eyes …..
Common on new builds to see the faded G/Y cable coming out of the wall to the pipe between the gas meter box and the wall with an indoor rated BS951 clamp corroded onto the copper pipe with a poorly made off verdigris cable stuffed into said corroded clamp.
My son rented a "recent" build house a few years ago. It had been lived in for several years at that time.Common on new builds to see the faded G/Y cable coming out of the wall to the pipe between the gas meter box and the wall with an indoor rated BS951 clamp corroded onto the copper pipe with a poorly made off verdigris cable stuffed into said corroded clamp.
I looked in the gas cabinet and spotted the bonding cable neatly coiled and pushed behind the meter
