Sebastian Kwiatkowski
Hi. I have IDEAL RS 80 N boiler. I just had anual gas bill for 1840 pouds. 3 bedroom house and only gas central heating. Electric cooker so i just need gas to heat my water and wall heaters. 2 adults + 1 child. Before the bill the plumber had to change a water pump because was not working at all. There is no water flow sensor in it. Is that boiler fault we had so big gas bill? Was it using a gas while heating and hot water was on and the air temperature was lower than on thermostate? We had cold wall heaters because of faulty pump so we weren't aware it has used a gas? Correct me please if I am wrong but i think the problem is there was no security system in a boiler and without water flow sensor boiler was heating up the water without water movement. Thermostat wanted a higher temperature so the boiler was heating up all the time.
Thank You if anybody will time to answer and sorry for my English.
Best regards,
Sebastian
Best regards,
Sebastian
