Hi all. I've put a few posts up about my first job, changing a consumer unit for my dad. When I took out the old unit I noticed that 2 of the 3 lighting circuits in his house were wired into the same MCB. At first I thought it was a ring mains to be honest until I noticed a 6 amp mcb there.
I've worked out why the previous electrician did this (I think). I separated all 3 lighting circuits on the new dual RCD board I put in today. The problem is that whenever the upstairs hall light is switched on (either from the downstairs or upstairs switch) it trips the RCD, but the one on the other side of the board, not the one the relevant light is wired into.
I'm assuming the problem is a borrowed neutral. When I remove the bulb from the upstairs light and flick either lightswitch nothing trips. This makes sense to me as there is no longer a return path down the neutral wire from the pendant in question.
So I think I've worked out what it is, but how do I go about confirming it and fixing it? Is it as simple as getting up in the loft and tracing the neutral wires and then sorting them out properly?
Everything else is working fine to be honest. The whole job was a bit of a pig to be honest, having to crimp lots of wires, extend the meter tails etc. An interesting first job!
Many thanks in advance for all help.
