Thats an older pamphlet M8, I assume its the new ones that are insisting on same make , or is it a reg as Slidey says .....BS 7671 ?
Its a PITA i know that.
No its not. The last 2 Wylex C/U bought since Xmas have that leaflet
Didn't you get that memo then??Serious question... has there ever been or has anyone any experience of danger/damage being caused by a good fitting MCB being installed into a board of a different manufacturer?
I can count on my hands the number of burnt out MCBs I've seen and they were just because of poorly tightened connections on the outgoing side, just one on the busbar side (all the matching manufacturers)
Think this is one were common sense and experience should prevail or there should be an across the board standardisation of MCBs and boards where anything will fit everything.
Not so seriously... they'll be telling us what colour shoes (sorry safety boots) to wear and which hand to wipe our backsides with next :coat
Thanks for that Sidey !Certainly Technician,
Straight from my electronic copy of BS7671 in raw data form:
"134
134.1
ERECTION AND INITIAL VERIFICATION OF ELECTRICAL INSTALLATIONS Erection
Good workmanship by competent persons or persons under their supervision and proper materials shall be used in the erection of the electrical installation. Electrical equipment shall be installed in accordance with the instructions provided by the manufacturer of the equipment."
(IET 21)
IET. BS 7671:2008 (2011) Requirements for Electrical Installations, IET Wiring Regulations - Universal, 17th Edition. Institution of Engineering & Technology (IET), 2011-07-01. <vbk:978-1-84919-531-7#page(21)>.
For those that missed the memo.....wipe with your left hand, eat with your right hand. If anyone steals anything you have your right hand cut off so you have to wipe and eat with the left hand........insh'AllahDidn't you get that memo then??![]()
