It's fair to say that outside the telecomms industry the 8P8C modular plug used in voice and data cabling has come to be commonly known as RJ45 although as you rightly say it is not.A plug for a true RJ45 configuration will not fit the jacks used for Ethernet, as it has an additional keyway. RJ45 is a configuration for the connection of an analog modem, with adjustable output power controlled by a resistance in the jack and set to match the line characteristics. It's rarely ever found today.
No, 4. One pair for the line, plus one pair for the connection to the resistance in the jack to set the modem's output power.RJ45's had 2 connectors
Yeah, It's a bit like the way UTP cable is refered to as ethernet cable.We're certainly fighting a losing battle over the RJ designations when even quite major manufacturers are now misusing the terms.
The resistor is housed inside the connector so it never left the jack hence its a 8P2C as only 2 connectors were usable.No, 4. One pair for the line, plus one pair for the connection to the resistance in the jack to set the modem's output power.
As opposed to STP?Yeah, It's a bit like the way UTP cable is refered to as ethernet cable.
miseducation for me thenA plug for a true RJ45 configuration will not fit the jacks used for Ethernet, as it has an additional keyway. RJ45 is a configuration for the connection of an analog modem, with adjustable output power controlled by a resistance in the jack and set to match the line characteristics. It's rarely ever found today.
It's a common misconception for anyone not from a telecoms background who has seen the widespread modern misapplication of the designation, so don't worry, you're not alone. (Just remember to set others straight now you know!miseducation for me then
The resistor has to be connected to the modem which is done via pins 7 & 8. The telephone line is on 4 & 5. For a line running from a 1A2 or similar key system, there would be another pair of connections for the KSU's A & A1 leads on 3 & 6.The resistor is housed inside the connector so it never left the jack hence its a 8P2C as only 2 connectors were usable.
Clearly my memory of them is somewhat different to yours then.The resistor has to be connected to the modem which is done via pins 7 & 8. The telephone line is on 4 & 5. For a line running from a 1A2 or similar key system, there would be another pair of connections for the KSU's A & A1 leads on 3 & 6.
