Builders kitchen refurb
M107
Billy-the-Kid
Feb 18, 2008
5,561
28
Berkshire
From todays job .......no not what I've done but another spark bought in by the builder (I've put a new cooker circuit in) ;
A socket & fused spur wouldnt be a problem if it wern't for the hob :C
http://i83.photobucket.com/albums/j293/gazjothomas/IMG00166-20120520-1232.jpg
The sfcu supplies the single socket below the worktop for a dishwasher. He said he'd find the cables no problem & knew wher they were for 2nd fix so they could board & plaster the walls.....:^OROTFWL
http://i83.photobucket.com/albums/j293/gazjothomas/IMG00165-20120520-1232.jpg
http://i83.photobucket.com/albums/j293/gazjothomas/IMG00168-20120520-1233.jpg
Find the cables no problem! So could stevie wonder with holes that big.
How singles are used in a domestic installation to extend a circuit.................oh sorry that how to strip T/E and make sigles for a domestic installation. Now if only I could fit a blank plate to enclose the joints :slap
http://i83.photobucket.com/albums/j293/gazjothomas/IMG00167-20120520-1232.jpg
What happens if you dont crimp correctly or check the joint......thats right you could loose the cpc.
http://i83.photobucket.com/albums/j293/gazjothomas/IMG00169-20120520-1234.jpg
Needless to say no certs or testing.
I think words will be had mate.
I did rewire the stripped single, with T/E & correctly exited through underside of pattress so I could put a blank plate on the pattress & used wagos to joint conductors. Only did this as I also had to move another socket on the same circuit.
So whats the point of joining a scam ????
if you understand the regs,, test and produce certs and your work is of good standard why should you when we find this everyday
no certs nout
100 quid a day sparkies no doubt
