you can get 400v coils. connect between 2 phasesthanks brian, surely the dol starter requires a neutral at one side of the coil supply end
swap the neutral to a another phase.....Hi Andy, thanks for the info, only ever connected a 230V coil, could you show me how this would be done using a simple diagram, not had much experience with 400V coils, cheers (MEERKAT)
I will second this, If I had relied on the information given by my course provider I would never have passed my exams, but following the threads on here gave me a real insight into how things work in the reall world.I can honestly say, I have learnt so much from you guy's on this forum, far more than I ever did at college, keep up the good work, and thanks once again !!!!!(MEERKAT)
Not vulnerable to test but will produce a dead short between the two lines.Hi all.Could anyone tell me if the three phase motor starter on the rig is vulnerable to an IR test at 500V?
I'm really not sure about this one.
I know how to IR test the complete rig but I don't know if putting 500V across L1-E , L2-E, L3-E will damage this starter.
I plan to test from the board first and then IR test from the three phase socket to the starter, you know do the three phase motor circuit in two halves.
Can anyone help me with this?
Thanks.
Why would it produce a dead short between two lines?Not vulnerable to test but will produce a dead short between the two lines.Testing in two halves is acceptable.
